Camera settings
I’m sure everyone knows you can’t change camera settings in pilot mode, but you can change settings in controller mode. FYI, you can change those settings even if you don’t have the controller. Just go into controller mode and swipe thru the instructions until you’re at the flying screen. Change your camera settings and then go back to whatever mode you wanted to fly in. It will keep those camera settings until you restart the quad or go back into controller mode to make other changes.
Hope this helps, and sorry if this has already shared.
Good point @TStover !
I did find that you can get to the camera settings in the other modes, but not until the Breeze is airborne. Sort of makes it difficult to shoot a white card to set the white balance and lock it. You can select one of the preprogrammed white balances though. It makes no sense why it was done correctly for Controller mode and not the rest.
Car20ret
