Camera Upgrade
I was wondering if anyone knew what to do about a camera glitching. My videos are always glitching in spots no matter what I try. I was wondering if it’s time for a new camera. Right now I have the CG03.
Anything will help
The Typhoon H normally has the CGo3+, not the CGo3. Please confirm which Drone / Camera you have. (see below)
Is the glitching "on screen", or is it in the recorded video.
What camera resolution, other settings, are you using?
What size and type of SD card do you have in the camera?
Reactions: NorWiscPilot
Are you watching the playback on the ST16? If so, that is normal.
After recording, remove the sd card from the camera and copy the video to a computer. Also note, the computer must be good enough to play the video.
wiebeedigital
