Cameria Spinning Around and Beeping
The Drone was fine and worked well. I upgraded to the latest firmware and we have a problem. The camera spins in circles and the Typhoon H does a constant beep.
check the dial on the upper left hand corner and be sure it is centered. If it is go to the hardware monitor and check that out.
Sorry about the late response. I have been out fighting crime with my TH. ;-) I found the hidden menu for calibrating the controller. Keep tapping on the "About Controller" and run through the calibrate test. It all worked fine.
Outstanding!! :)
FlyingVegetable
