CCC editor online - Version 1.7C
Hi everybody, I'm working on a CCC editor.
you can find it here :CCC editor for typhoon H
You can start an empty CCC
Or you can upload one of your mission file to see it, modify waypoints and add waypoints
have a look, try to see if you understand...
So if you think I'm on the right way or not, just let me know...
I will make a real test tomorrow, one from an empty CCC and one from a modified CCC ;)
TESTED !!! and approved !!!
IMPORTANT : I DID NOT TEST IN REAL. IF YOU TEST A CCC FILE IN REAL ON YOUR TYPHOON I'M NOT RESPONSIBLE OF ANYTHING
CCC output file looks right. TOTALLY GREAT WORK. Why Yuneec, why Yuneec is not published this kind feature... But now we have.
Your definitely onto something good here. It's a little rough around the edges.
Is the alt the altitude setting in meters?
Who will be the first to fly a mission?
Yes altitude is in meters
It's a beta version, many adjustments left to be done...
I will be the first tomorrow !!!! :eek:
Reactions: Graeme Buckley
Be careful with file format, I mean line breaks. I have made many mistakes with line breaks when editing with windows and using in Linux or Android.
And again, great work!
And I assume the arrow show what way the camera is pointing.
Can that be adjusted yet.
Great work by the way, I will make use of this editor a lot when done.
At this time, the green arrow is the yaw (the direction where the th is pointing). In fact I can set up the th yaw and the gimbal yaw separatly. But for the moment, I'm first waiting for tomorrow and my first test. Improvements will come later.
I go STEP BY STEP !
Really great work Eric, hope you get it all figured out. This could end up being the best option the Typhoon has.
ERIC !!!!! go on working it out... great work ! we need it... maybe you can sell it to yuneec, because they sleeping ;):):)
can i edit the YAW of copter with Mouse? and how i delete a point?
Well done and thank you!
Nice work Eric.
Didn't try CCC yet but going to try with this.
Windguru giving 42 kts gusts with you tomorrow.
H will be working hard..
Reactions: Eric
Please be very careful folks. The Typhoon does *NOT* follow a CCC route in a straight line ('Curved' Cable cam!) so if you're near to obstructions, what appears straight on the map will not be flown that way and can cause collisions.
I go STEP BY STEP !
Awesomesauce Eric!! I wish you good luck tomorrow and I can't wait to hear the results.
drohnenstarter.de
