CGO2 app for tablet?
Freesoil Michigan
Hi. Hope someone can help. I cannot seem to find download for cgo2 camera for use on tablet with the handheld device. I tried a generic and it wanted to fill me up with games. Hoping someone can steer me in the right direction Keith
You might give this a try. I don't know if it will work or not. I saved if from my CGO2 days. Download it from this link:
Hi Steve. Thank you for the reply. I tried the site apkpure.com.apk, and somehow it would not load. I use my wife's tablet for this,and it's so full of pictures,unbelievable. Anyways it wanted access to pictures and her sd card,then it just kept showing me games. Then I started looking through the tablet and lo&behold there was my original cgo2 app somehow put on hold?? Time to get the cgo2 out and capture some of the wind and waves here on lake mi. Too windy to fly,,safely. Thanksmuch Keith
I have made a simple command center for the CGO2 to start video, take pictures and so on.
It should work on any system that is able to connect to the camera wifi.
It also describes how to get a video feed (viewfinder) with VLC or similar.
Download the file to your device, name it cgo2_cam_command.html
It is a simple html file.
Open it with your default browser and have fun.
URL to Google Drive was a dead link and has been removed by @DoomMeister
Hi. The file is no longer available. Could you upload it again? If that really works, it would be greatly appreciated! Thanks!
Hi.
I don't have such an old android version available just now...
I cannot install any of the CGO apps on android 15.
I have the cgo2+ working with the rtsp app called Onvier, though...
Kr, Roy
The CGO2/3 cameras have a build-in webserver that offers HTML-, DHCP-, RTSP- and maybe other services that are needed to setup a WiFi network, video stream and control camera.
Video resolution depends on bandwidth of the network and the performance of the HW (processor , interfaces...). Change the resolution of the video stream over WiFi needs a different firmware. You can try to create another FW with more capabilities but hardware restriction will be remain. I doubt that the CGO2 will be able to do more.
The full video resolution is only availbale on the SD card in the camera itself.
My phone has Android version 13. CGO app and CGO4 app all working. The Yuneec Pilot app for Mantis Q works partially. I can control all function but do not get a videostream.
Write your reply...
Oliver28.
