Need more info.I made my first video today and I notice on playback in my laptop that the video is very choppy. Is that a common issue or a fault of my computer? Thanx
Need more info.
Is the footage 4K?
Is the footage from the controller or directly from the aircraft's camera?
What specification is your computer?
Etc.
If your source footage directly from the camera at 4K the problem may be more to do with your computer not being able to handle it. If the footage is 1080p then it may be more to do with your computer not being able to run your editing software properly.
Without a bit more info from you it is difficult to say what your problem is.[/QUO
I'm new at this, obviously. The computer is rather old; a Toshiba Satellite L775 running Windows 7 Home 64 bit with an Intel Pentium B950 CPU, 2.10GHz, and 4 Gb memory, so I suspect the problem lies with it. The video was direct from the camera, I was under the impression that the SD card must be placed in the camera. The instruction manual does show that the controller has a card slot, but doesn't mention when or why I should use that instead of the camera. Can you enlighten me? I do notice occasional issues with the computer when editing stills in Photoshop. Thanks
Bpess54 hasn't stated what flight platform he is using. If it's a Q500 then your statement is correct. If it's a Typhoon H then there is no need to have a card inserted into the ST16 since the telemetry is stored within the ST16. If that's the case then all that the SD slot in the controller is useful for is copying the telemetry or other files out should the need arise (assuming he doesn't have the UAVtoolbox app) and to do off line firmware updates to the ST16. I only use the SD slot in the ST16 for firmware updating.Card slot in controller will capture the Telemetry Data. If a problems arises Yuneec will most likely want to see the Telemetry Data. My suggestion is to never fly with out a card in the controller.
You could still be right if what he is flying is a Q500. Maybe he will come back and tell us what he is flying.@FlushVision Yep I didn't pick up on his platform. Sorry for confusion.
