compass calibration question
I have never seen that you are instructed to calibrate the compass every time you use the Typoon H.
What kind of screen is it?
You do not have to calibrate the compass before every flight. Only when there is some indication that you are having a compass problem would you calibrate. It has been months since my last calibration and I have had many flight since then with no problem.
I’m assuming you’ve calibrated once when you first started? There is no screen other then the calibration menu will stay on screen during calibration. Since it’s all monitored by progressive status lights at the model, the ST screen just sits there. I always make sure the H is fully level before hitting the calibration button because I’ve more then once fat fingered it into accelerometer calibration and it must be level and still during that auto calibration procedure.
gabrieliu
