Connecting 2 "h" drones to the same st 16.
Is this possible? No, I don't want to fly 2 at the same time but I am trying to eliminate some issues with one of my h's connection to it's st 16. There is no problem with the other 2 I have.
Peter,
Yes, you can set up as many drones as you like on the ST16. Just create a new "Model" for each one, and remember to select the correct Model when you want to fly.
The drone types that are compatible with the ST16 are:
Q500
Typhoon H
Tornado H920
Reactions: ArtCox
Hm. I can actually fly the h, q on one st 16? I really should have known that.
The Q500 flies well on the ST16, but the video screen has a lot of "artifacts" sparkling on it because of the difference in camera WIFI signal. Some are much better than others. If the CGo3 is on the latest firmware, it looks pretty decent. Older CGo3 firmware, not so good.
You might want to bind it and see how well you can see the screen before actually flying the drone.
The pictures and video recorded on the SD card are always normal, regardless of firmware version.
Make sure you give each TH model a unique name so you know which to load when you go to fly.
happyrenovators
