Can this be shipped to the US from the UK or should we look for something here in the US ?
Non reversible thermal stickers should be available from any decent electronics firm, same as for heatsinks.
The more light an object absorbs, the more heat is absorbed, because light is energy. If you consider colors, black absorbs the most heat. A black object absorbs all wavelengths of light and reflects none. Objects that are white, on the other hand, reflect all wavelengths of light and therefore absorb less heat. The flat dark charcoal grey, almost black color of the roof-plate is not helping matters. When you couple the absorbed heat of the roof with the internal heat that is generated by the electronics, the total heat of the craft is greater than if you only had the internal generated heat. Therefore Painting the roof glossy white, will in fact reduce the total heat of the craft. I'm not saying it will solve the Th problem altogether but it will in fact reduce heat.
