Creating a drone flight trace on Google Earth: by using a spreadsheet
Creating a drone flight trace on google Earth:
by using a spreadsheet and GPS Visualizer website
(for Yuneec Breeze flight log data in App controller mode)
You can use a spreadsheet, a website named GPS Visualizer and Google Earth to display your Yuneec Breeze’s flight path. It takes some effort but the resulting KMZ file can be archived for viewing later. Here are the steps that I used:
1-copy the flight log to a new directory, rename the log file with a *.txt file type extension and open the text file
2-highlight all of the entries, copy the data (ctrl-C), open a blank spreadsheet, select cell A1 and paste the data (ctrl-V) into the spreadsheet using a comma as the delimiter
3-the pasted flight data looks like this in the spreadsheet
4-if you want the UTC data to appear in column 1 then highlight column 1 and format the time as shown here (otherwise skip this step)
time reformat:
after reformatting:
5-highlight and copy the 2 GPS (lat / long) data columns as shown and paste to a new spreadsheet
Drone path GPS conversion (and Google Earth visualization) from the Yuneec Breeze's flight log using a spreadsheet and 'GPS Visualizer' website
(Press text link to display)
6-the GPS data needs to be divided by 10000000 (a one followed by seven zeros) to be valid. Enter the formula shown here to cell D1
7-apply the formula by pressing enter. The valid GPS entry appears in cell D1 and is derived from cell A1.
8-select and copy the ‘value’ (contains the formula too) of cell D1.
9-highlight the cells in columns D and E
10-select ‘edit and paste’ from the menu or press ctrl-V to apply the formula to the highlighted cells
11-copy the highlighted cells in columns D and E to a blank text file.
12-upload the text file containing the ‘valid’ flight log GPS data to the website ‘GPS Visualizer’
GPS Visualizer
using ‘Google Earth ‘ as the output format.
'GPS Visualizer' website, generated Google Earth kmz file and its display in Google Earth
13-the website will process the file and return *map.kmz file which Google Earth can open and display.
Yuneec Breeze orbit path
Reactions: DoomMeister
Nice post MB53!!!
You may also be interested in this program Q500log2kml by @h-elsner available at Meine private Homepage - Programmierung, Kopter, Bilder in the download section. It is available in Windows 32 and 64 bit versions, as well as Linux and iMac. It is standalone so you don’t have install and can be kept on a thumb drive.
droneforce1
