dark corners only on pictures
I had a small crash with my q500 only 5 ft rom the ground but the bushings from two of the four post
  • if the lens is not locked and flush to the gimball cover it will happen
    Votes: 0 0.0%
  • you have to rest the camera
    Votes: 0 0.0%
  • Total voters
I had a small crash with my q500 only 5 ft rom the ground but the bushings from two of the four posts on the gimball had to be put back in. I noticed after i took additional more pictures the outside corners had darkened corners
Yes, looks like the camera body is out of place, or the entire lens and camera board were pushed towards the rear.
If you do a forum search on "lens replacement" I think you will find a couple of videos that show how to disassemble the camera and put it back together again. Willing to bet the camera board is not seated in there correctly causing you to catch the outer frame in the picture.
Thanks I pulled the oblong lens cover off the camera front and put it back on again it appears to be much better
mining_drones
