I'm careful to not overcharge LiPo batteries. As I don't really know how the Yuneec charger works, I'm careful not to keep the battery on charge for extended periods after the light turns green. My "good" LiPo chargers monitor each cell in the pack (2S - 10S) and charges each cell to 4.200 volts. Should one cell not charge as fast, the charger stops charging the good cells and only charges the low cell, bringing it up to the other battery voltages before charging continues. When charging is complete, and each cell is at 4.200 volts, charging stops - no more voltage / current applied to the battery. I'd like to think (HOPE) this is similar to with the Yuneec charger, but I really doubt it. Point is, when I typically start a flight, my battery starts at 95-99% and drops somewhat quickly from there. I mention this as I was flying tonight, just messing around, and I started the flight at 100% on the battery and it stayed there for at least a minute (maybe longer) before dropping to 99-98-97%. I was amazed and thought, perhaps I'm not charging the battery long enough to reach 100%, but I pull the battery off the charger when the green light comes on (let's say, within an hour of the light coming on).
I'm curious if others start with a reading of 100% on the phone indicator, or do you start with less than 100% and it drops from there somewhat fast.
I'm also trying to determine if, what I consider to be not long flight times, could be due to me not charging the battery fully.
I am charging my batteries now and want to start at 100% again before measuring flight times.
Also, somewhat interesting, I looked into Drones with longer flight times - as I'm sure we all have. The Parrot Bebop Drone 2 seems to have a flight time of 25 minutes, at least 2X the Breeze - and I looked at pricing, and battery cost, and controller, and WAY TO MUCH MONEY for me at this point - just starting with drones. I'm going to stick with the Breeze for a while and see if I can charge the batteries a bit more, then check flight times
