Drone isnt showing under bind
Jjust the add one the prop lights flash red at back while the front they flash white 3 times and the main light is flashing orange super fast
My first try would be to create a new model from scratch and try to bind MK58 and drone to it. If then the drone is in bind mode and the SR24 ID will still not appear in the bind menu then the SR24 receiver module may be defect.
Reactions: Pier2162
Hi Nathan
This pattern means the drone is in Agility mode with loss of GPS.
Which main light??
How did you put the drone in bind mode?
Hey thank, I've managed to fix it. There was a wire thing on the inside where the battery is what wasn't fully connected
Reactions: Pier2162
snoopy68
