Drone motors
Hey guys when I start the q500 all props spin but one struggles then if I give it throttle it spins should I just order a new A motor its the front right 20201202_111001.jpeg
It could be the ESC causing the trouble also. I would suggest checking the drone on the GUI first. If things look good there try swapping the front and rear A motors. If the problem moves with the motor it is bad If it stays at the front A spot it is the ESC or power feed to the ESC. This will save money by knowing which part/s to order.
It might also be a bad connection or a broken wire. If there is something like a poorly soldered connector or ripped wires, the motors have a tendency to causing trouble while accelerating.
Also check if all magnets are in place. Sometimes they get lose which might cause similar problems but usually it is accompanied by a changed sound.
Reactions: DoomMeister
When I spin the motor with my hand it sounds like a rattle
On the gui it says all the esc are all good I might try swapping both A motors thanks heaps good idea
If the motor giving you trouble doesn’t spin well by hand. It likely has dirt in it or the bearings are shot or need lubrication. With a prop mounted spin it slowly with your finger. You should feel a slight pulsing as the rotor moves past the magnets of the stator. If it is grinds, sticks , or feels wobbly just replace it.
A rattling sound is usually caused by worn out bearings. If a magnet is lose it would be more like a clicking sound. But a broken bearing might also cause problems like that. I never experienced a bearing that worn out but it might be possible. Usually you swap them out as soon as you hear something strange. The motors often will be a little warm as well. So in any case I would recommand to replace this motor or if you are capable of (little bit complicated) replace the bearings.
shamrock@78
