Elevation speed
Hello. I have purchased a Yuneec 520 primarily for farm use. I am having trouble with a very slow speed to climb and descend.
How do i change the elevation speed
Cheers Andrew
Cheers Andrew
First check the settings for Vertical rates from the "Safety" tab in the menu:
If that is not the issue, check the rate slider on the right-hand side of the controller to ensure it is full up.
Also check the "RC Monitor" to ensure "J1" and "K3" are moving full scale and smoothly.
Conversations
