- Joined
- Jun 22, 2017
- Messages
- 85
- Reaction score
- 15
- Age
- 61
It seemed a bit confused at the start - is that the difference between Watch Me and Follow Me? Never used either option so not sure.Yea, hard lesson to learn, hope you can repair the H.
Amazing animal it is. I did similar 18 months ago. Misjudged the distance to a 75' flag pole. Smashed straight into it. It turned vertical from impact, dropped 5' and went into hover. I landed and found two broken props opposite each other. Zero damage otherwise.I looked back and saw black parts flying figuring it would be a total loss. little to my surprise I turned around and it was still trying to follow me. Put the gear down and landed to find 2 props clipped about in half on one side and the cam was gone. It was hovering quite well with the props only half complete on one side.
I love my H...highly under rated - Yuneec are definite challengers to DJi...the H920 is my next machine for sure.Amazing animal it is. I did similar 18 months ago. Misjudged the distance to a 75' flag pole. Smashed straight into it. It turned vertical from impact, dropped 5' and went into hover. I landed and found two broken props opposite each other. Zero damage otherwise.
Nothing remarkable in the telemetry. It is a bit odd the file ends before the end of the flight however.telemetry file
not sure what you see. please explain...I noticed the 0 altitudes in several placesNothing remarkable in the telemetry. It is a bit odd the file ends before the end of the flight however.
The altitude is reset to zero when you start the motors. For most of the flight the altitude stayed around 3 m in the telemetry. The file ends while the H is still airborne and at 3 meters.not sure what you see. please explain...I noticed the 0 altitudes in several places
When you are in team mode, if you see telemetry on the left side of the screen, it will be recorded. But that would mean the H is bound to the ST16 rather than the Wizard, so the short answer is, no, the ST16 won't record anything unless it's bound to the aircraft.I was in team mode. So was telemetry collected?
