Firmware Update Failed (Solved)
Hello,
I tried to preform the OTA Update on the H520 w/ E90 Camera.
The update got to 85% then said it faile.
Now the camera hangs there like a limp noodle, The Controller will connect to the H520 and show video on the screen
But it says "Not Connected" instead of teling me what camera I have.
If I try to do the update again to complete it. It will connect to my WiFi then it connects to the H520.
I get the Orange screen like it is going to update but the screen says "Connected E90" then Unable to connect to Drone.
If I try to update it from the flash card directly using autopilot.yuneec this is the log file that it generates.
found /tmp/SD0/autopilot.yuneec to update
file size: 1334532
found board ID in JSON: 66
found iv
found encrypted image
.yuneec JSON parsed
base64decode compressed image len: 960365
base64decode iv len: 16
base64decode uncompressed len: 960064
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
failed to get reboot acknowledged at 500000, continuing anyway
could not talk to bootloader, giving up
Any help would be great.
Thank you
Hello,
file size: 1334532
found iv
.yuneec JSON parsed
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
Thank you
One of the first things to do before posting a question, is use the search tool to see what has already been posted and answered by other members. The search tool is located to the upper right side of the screen indicated with a magnifier icon.
I used it and entered these search words...... H520 firmware.
Here are the results.
Search results for query: h520 firmware
Please use the search tool always first so that we do not have repeat questions clogging up the threads.
Thanks
Murray
Ofc I did a search for this problem. The closes I could find was to download an old firmware, with no link to where I would be able to get an old firmware as Yuneec does not have them posted for download. I guess I should start my posts with "I searched the forums" If I had found the answer I would not have written and contemplated such a long post.
If I missed the answer somewhere in the forum sorry for the post and feel free to remove it and please reply with the link to the correct one.
Thank you
Jason
Reactions: Murray Martz
I just got off the phone with Yuneec Support. They were useful in that they knew the issue and said it cannot be fixed. This started to happen with the new firmware that they posted 2 weeks ago and I guess is it crashing the bootloader. They are sending me the paperwork to get the E90 replaced.
Hope this helps anyone else that has the same issue.
Thank you all again.
Hello,
file size: 1334532
found iv
.yuneec JSON parsed
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
send reboot
Thank you
Uninstall DataPilot Then launch software updater everything should go through after that, Data pilot Will be reinstalled along with all the updates
jonnyelectric
