Download the .zip file and extract the contents, included in the other files is an .html file. click on that file and it should open in your browser, it has the instructions.I hate to be a bore here, but can someone be so kind as to supply a link to a previous post as to how to install Tuna's fine app? Or, maybe just a quick bullet point install and access procedure for the files? Thanks in advance!
Perfect! Exactly what I needed. Thanks!Download the .zip file and extract the contents, included in the other files is an .html file. click on that file and it should open in your browser, it has the instructions.
Thank you...but where is the link?Version 1.6 is here, download at the link below.
New features are a settings screen, satellite map views and imperial/metric display units.
If your app had expired, download the latest one and enjoy!
Bill W.
I installed the beta directly using my st16 in pad modedidn't read all 149 post of this thread, but, can you install this directly from the ST-16 in " pad " mode over wifi on the web ? Or do you need to go trought a PC ?
Thats what i did.K thanks ! so i guess, you use the ST-16 web browser. Come on this page here and click on the link from Tuna !?
You used to be able to copy the files to the pc . To make Dashware work. It now times out everytime instead of getting the option to save. All other things work fine this is an ACW app.
Will this fix maps not loading for some Tuna?
Tuna, it took you 5 minutes to fix that bug....you're really slipping.![]()
