"Help avoid crashes" nothing's fail-safe, but no worries.Ok Mrgs, I was just telling that it needs 12,5 minutes to be on the safe side. Just idle 13min if you don't have an Atomic Clock. My point is info to avoid crashes, nothing else.
I agree PatR, but still I insist that a 100% completed and up-to- date GPS almanack is a cheap and simple way to minimise GPS failure... Ok?I apologize if it appeared I was leaning on the OP in my previous comments referencing non GPS flight operations. That’s not what I intended. It was meant that as drone pilots we absolutely must learn how to effectively and accurately handle our aircraft when GPS position assistance fails. Not if as it will most certainly do, but when.
Those that develop their flight control skills have the ability to mentally “shift gears” when a GPS failure occurs. They’ve learned how to compensate for wind drift to maintain a constant course, can hover with a good level of position accuracy in light to moderate winds, and can get the aircraft back to where it started without needing to use RTH.
Flying beneath a tree cover, through a covered bridge or tunnel is not a problem for them. Some learned on systems where flight modes named Atti or Stabilized were present that did not provide a GPS assist. The Typhoon H provides similar when switching off GPS and is something that should be explored and practiced by everyone that’s serious in becoming a competent drone operator.
As altitude hold is not dependent upon GPS that part of the workload is largely removed from requiring constant control input. There will be times where the use non GPS assisted flight will be the only way to complete a flight or particular type of mission. There will be times GPS signal is occluded by objects or structures. Those that can fly without the help of GPS will be less prone to incidents and have a higher mission success rate. We need not be surprised or restricted when GPS fails, we just need to be ready and able to take control of the aircraft and fly it appropriately. We have a choice between being masters of our aircraft or just along for the ride. One way takes more practice but that way experiences fewer incidents and instills confidence through competence.
Mode should not really matter. We don’t need functioning GPS to fly with accuracy. GPS is both an assist and a crutch. If we can’t fly accurately without GPS we don’t have our piloting skills together yet.
I wouldn't regard Smart mode as smart, I never use it.I agree. But how does your comment concerning GPS equate with flying in Smart mode vs Angle mode? My understanding is both modes utilize GPS.
AH1... do what ever you want, it's was just facts I picked up from those who knows how GPS Ephemerides and Almanacs works. Just switch on your hexa and take off!I stand by my method not to wait and waist 13 minutes!?![]()
Hello everybody did I hear someone said they landed a TH with the legs still up. Well I have a TH.What Yuneec model were you flying?
Don’t fly into trees, lower the landing gear before touching down ?
Thanks for the information my fellow flyer. I thought I was on the one with thinking about that but I'm glad I'm not.I apologize if it appeared I was leaning on the OP in my previous comments referencing non GPS flight operations. That’s not what I intended. It was meant that as drone pilots we absolutely must learn how to effectively and accurately handle our aircraft when GPS position assistance fails. Not if as it will most certainly do, but when.
Smart Mode has the right idea, with geo-fencing and altitude restrictions, RTH safety radius......the big “No-Go” for me is it operates the aircraft in Headless Mode. That ruins it for me.
Main thing is you got it down in one piece and it lives to fly another day.I'm still pretty new to drones and certainly don't consider myself a competent flyer. However, I've read many posts and reviewed the manual. Either the first or second time I got a low battery warning I wasn't sure which way my H was heading and due to panic as much as anything I almost instinctively switched on Smart mode. I was able to bring it back promptly and landed after returning to Angle mode. Smart mode worked for this nervous Nellie.
