Just curious if anyone has ever removed and soldered in a new GPS module battery? Wow they are small, I think I'll need smaller tips, any tips on fitting except being careful.
Doesn't need replacing, just asking in preparation. Some have had to replace module when they've had a failure, battery is a lot cheaper than module in UK.Easy to do if needed. But why do you need to replace it? It should last a way longer than the oldest Typhoons are at the moment. Does the GPS do a cold start every time you start up (although with NEO M8 it should be around 30 seconds)?
The battery voltage is easy to check if you have the top shell removed.Hmm. That could actually explain, why on the first flight of the day, it takes around 30 seconds to get any position data out of the GNSS, and after a (flight) battery change, I get the position immediately... ;-)
The compass is also located on that module. I have always assumed the battery was providing power to maintain the compass calibration and the almanac data. But that data is only good for 24 hrs, so it takes longer to get a good GPS fix if the H hasn't been flown in a couple of days. Waiting on the first flight of the day is always a good practice.
Always give it about 5 minutes or more before takeoff, EU DFS slows it down anyway 90 seconds or more.
I have topshells with module in ready to go, I'm not sure the copter would be adversely affected by a non charging battery.
I already have spare top shells complete with modules. It was about sharing tips if anyone had any.You should just pick up a spare GPS sensor. I have two. I purchased them both from eBay for 10 bucks each.
Turning on ST16 first, putting on props and checking and making sure everything looks OK, inserting battery, turning on copter, and waiting for camera to connect, 5 minutes is no big deal, especially if it's not been used for a while, everyone has their own regime as they say.
Some have reported a 45 minute refresh, after a long period of down time.@Mrgs1,
Good point, but there IS a but here...
In your example, 5 minutes from ST16 power on is, agreed, no big deal. But... 5 minutes after powering on the aircraft itself CAN seem like a long, long time to wait.
It is the latter that is most important! Getting the aircraft ready, including GPS data, is more important than the ST16. Especially if the aircraft has been idle for several days, as has been discussed often, it is highly recommended to allow the aircraft to sit, powered on, but motors off, for the 12-15 minutes GPS almanac refresh.
(Repeating here in anticipation of any readers who may not have previously read about the almanac refresh recommendations.)
That make sense?
Respectfully,
Jeff
Then there is something very wrong with the GPS unit of the device if Time To First Fix (TTFF) takes 45 minutes on a modern uBlox GNSS chipset. Replacement is required here. Please refer to the datasheets above regarding the uBlox' chipset performance. ;-)
Pollo,
I’ll suggest to take a short break from toy grade drone forums to visit the world of full scale aviation and avionics. While there, research how much time will pass GPS manufactures make reference to new installation boot up time and positional accuracy. They also explain why.
Understand all their systems are FAA approved and certificated, and must be installed and tested by licensed avionics technicians and avionics service facilities. Recognize they are describing the best equipment under the best conditions, a couple things our toy GPS units are bot afforded.
Hint: you will read that some units will require up to an hour of power on time before they become usable. I can assure you that what is used in multirotors is not nearly well made, sophisticated, or accurate, and if allowed to sit powered down for extended periods of time forget where they are.
