I took a look at the 00056 flightlog which I cut down to the area of arming the motors to the end of recorded telemetry from the aircraft. Comparing inputs on the controller to aircraft response I never saw a loss of RC control. Each change in stick inputs or fight mode showed up in telemetry with the exception near the end when RTH was activated and the aircraft did not switch out of angle mode. This may be because the aircraft was in Angle mode without GPS and RTH requires GPS.
The following graphs show the aircraft reaction to the stick inputs and the changes in flight mode from 21 (Follow Me), to 3 (Angle), to 4 (Angle w/o GPS).
CH10 is the Landing Gear switch (0 is up and 4095 is down), CH4 is the Mode Switch (Smart-3412, Angle-2048, RTH-683), and CH5 is RTH (0-off, 4095-on)
