Phaedrus
Premium Pilot
Are the stick pots on the Yuneec ST16/ST16S sealed? If so, you cannot "clean" them.
The other question is, how are the stick pots held in the gimbal? Is it possible for the pot to possibly move which would result in the observed issue.
If you have a sticky stick problem. Here’s my solution (I have not had any sticks problems, with my ST16s) but every 2mos I maintain my equipments. From YUN to DJI.
2 simple things that I use for contacts.
1) #2 Eraser
2) DeoxIT Spray Contact Cleaner and liquid for tight spots.
I have done this on my DJI controller slave after I neglected it for a long period of time and the yaw stick was off center. I tore it down, clean and remapped/calibrate.
I maintain by cleaning the contacts due to the dusty locations where I fly. If you cannot disassemble the pot, put liquid contact clean this will help dissolve any gunks. The sticks also needs TLC. All of the advice on this thread are great. If you are not willing to through the RMA waiting process, I would suggest of setting a time to digest all of the advice and commit in solving the problem to what you think is the best.
Good luck.
A dirty pot is one of those things that a Tech at Yuneec has missed on many occasions only to have the customer do a dis-approving write up on it here which; is why many of us plead with a new owner in these threads to please clean the sticks first to save a lot of time. It doesn't help that no where in the instructions or the 'official' manual do they warn of this scenario. It is sort of one of those things that perhaps at the factory they never witness because it takes a while for this problem to occur.
If Yuneec would go to the optical readers on the sticks (like on many better RC controllers) they could almost totally eliminate this problem (can still get oxidation in connectors, but rarely).
