- Joined
- Mar 4, 2017
- Messages
- 3
- Reaction score
- 1
- Age
- 70
I've searched through the forum but I can't find an answer to this question. I have just purchased the Typhoon H with intelisense. I've not flown it yet. I notice that two of the rubber gimbal mounts are not installed correctly. On examination I managed to disconnect the other too. OK, I'm an idiot but I thought it was going to be fairly easy to refit them. I was wrong. The two without the pins went back after some fiddling but I can't get the other two back in place. I did look at a youtube video but this was for the 500. The H plate does not have any access to the top holes from the outside. You have to fit the mounts in the top first and then try to get them into the lower plate. I've tried right angled pliers, and an allen key with a ball end to try and push and pull them through. I've just given up and come here for help.
It also seems that there is no way to remove the pins from the top plate, buy I maybe wrong on this.
A
A
