- Joined
- Oct 30, 2016
- Messages
- 1,201
- Reaction score
- 439
- Age
- 47
idem same error with Windows 7 64bHello thanks you but it starts badly, Datapilot for windows does not work: "the application failed to start correctly (0xc000007b), click Ok to close the application"
Claudius this worked. I am running Windows 10 on a ASUS laptop. I also received the error "0xc000007b".Good problem solved. For Windows 7 or Windows 8.1, if you have the error "0xc000007b", you must install or reinstall "Microsoft Visual C ++ 2017 Redistributable (x64) - 14.11.25325".
If you have the missing File: api-ms-win-crt-runtime-l1-1-0.dll error, you must install (for Windows 8.1): "Windows8.1-KB2999226-x64.msu"
And it works.
But what a sadness compared to Litchi Hub, no POI, no poi sight, no elevation of terrain to calculate the height of all points (especially in the mountains).
I hope that with the SDK, someone will make a better program, because there, they are not at the top.
What software are you referring to?There isn't any software for the 520 and I'm not happy after paying the best part of £5000 in the cost of the drone and camera's I'm not happy
if yuneec think that ill use the controller to do my work on we will be in court *** fast
You might try this link DataPilot Desktop or get in touch with Yuneec here Contact and ask them where you can obtain the software.There isn't any software for the 520 and I'm not happy after paying the best part of £5000 in the cost of the drone and camera's I'm not happy
