How do I check the CGO3 firmware version #
Good question and I'm not sure there is a way. Others may have a way for you to check.
I would simply load the firmware I want onto the SD card and insert the card in the camera for updating.
Others may have some ideas for you too.
Good luck,
Jafo
I quess if its the same firmware version that your trying to load is the same , nothing will happen but if it's an earlier version already installed the newer version will do its thing and update. That's all I have to go on for now. And come to think about it the camera is doing everything its suppose to be doing. so why mess with it. But going back to the original question, How does one see what CGO3 firmware version is installed?
aicyberwatch
