I have not but a good friend has and the quality is very good.What is the quality of this lens ?
Did you tried it already ?
kind regards
Marnix
kind regards
Marnix
What I saw from my friends lens was more like 87deg or a little less contrary to their advertised 90deg. (referring to the link I posted).![]()
+1I found what I believe to be the Chinese origin of the "Peau" lens selling for $50 shipped....all specs are similar except it is 3.8 mm no designated 3.9 lens seems to be manufactured over there that I could find...perhaps the 3.9 designation was to throw folks off the trail who wanted to deal directly with Chinese supplier...the 3.8mm is metal with glass elements and with an IR cut filter field of view is 82 degrees. By the way to get the equivalent 35 mm camera lens value from these lenses just multiply the number by 4...so a 3.8mm M12 board lens in 35mm camera terms would be approx. a 14mm lens...a 5.4mm lens would be approx. a 22mm lens.
This is mad, it seems we have at least 2 different lens boards...One with sony markings on it and one with something else...I have other type of lens holder in my Typhoon H.
I have been very surprised to see it.
Glue cannot be removed. It is possible to tear off a lens only.
There is no thread in lens holder!!!!!! Diameter of lens holder is bigger than diameter of a lens and the thread of a lens hanging in the air!!!!!!
We have put other lens holder, now everything is OK.
My trust to engineers of Yuneec has promptly decreased.
I've come across this autofocus 3.7 lens for a M12 out, the thing is the autofocus is inbuilt and seems to work by using a voltage regulation to shape the lens, now if someone expert in electronics could see if there was any way to wire this to the sensor board, we could maybe control focus by mapping to one of the game pad joysticks.I found what I believe to be the Chinese origin of the "Peau" lens the selling price is as low as $30 in quantity and for 1 is $100 shipped....all specs are similar except it is 3.8 mm no designated 3.9 lens seems to be manufactured over there that I could find...perhaps the 3.9 designation was to throw folks off the trail who wanted to deal directly with Chinese supplier...the 3.8mm is 16 megapixel resolution, metal with glass elements and with an IR cut filter field of view is 82 degrees. By the way to get the equivalent 35 mm camera lens value from these lenses just multiply the number by 4...so a 3.8mm M12 board lens in 35mm camera terms would be approx. a 14mm lens...a 5.4mm lens would be approx. a 22mm lens.
So whats the logic in it being able to focus?On the size sensor that the CGO3+ has with a 3.7mm lens you are already in focus 7cm to infinity. You're not really going to be doing focus pulls with it
With videoconferencing also listed as one of the applications it's designed for it would be interesting to get more information from the manufacturer.It's a medical lens used in Endoscopes you would have another set of lenses infront of it.
third parties are already doing this for customers
Why don't you go to SanDiego and have Peau do it. As for CraigCam's comments, different strokes for different folks. I'm in Iceland now where there is no one but me to fix anything on my H so I've tried to learn as much as I can about repairs and mods so I can repair and mod in the field if I need to. I think people would be wise to do the same if they are doing this professionally and may need to do impromtu repairs in the field. I own about ten different lenses and used to swap them quite often when I used GoPros...the people designing these don't really know that much about optics and cut corners when they shouldn't sometimes...I enjoy hacking and improving them and often and you will soon see companies eventually see the handwriting on the wall.
Craig I began my first response to you with "different strokes for different folks" which I believe means your quote "Your situation is very different than most of us." I'm in a position to basically do what I want when I want and I could care less about warranties if it has a bearing on the quality of the work I produce. HAPPY NEW YEAR
