- Joined
- Nov 27, 2018
- Messages
- 8
- Reaction score
- 1
- Age
- 60
Thanks, I'll give it a try2 more things you should be aware of:
1. For unknown reasons, pressing the trim pads for the first time resets white balance, so if you are going to be using cruise control and want to lock WB, then you need to tap the trim d-pad up and down once before you set it so that it doesn't get reset to Auto WB when you start the cruise.
2. Be aware that the rates control (turtle-rabbit rotary) also affects cruise control speed, which has advantages and disadvantages. You should be in full Rabbit mode to make it work most efficiently, otherwise you could press the up arrow 20 times and still only get the slowest possible movement if your rates were left in Turtle mode. Unfortunately this means you cannot use the rates slider to smooth out your yaw movements without also drastically slowing the speed of the forward procession. A sort of compromise is possible if you keep the rates slider at the half-way point, or if you know what you are doing you can leave it in Rabbit mode, and set some custom expo in your yaw controls instead.
This behaviour works to our advantage when we want to smoothly speed up some initially slow directional movement, which we can now do via the rates control rather than by inputting additional forward clicks on the D-pad, where the stepping effect can be quite noticeable.
Thanks, I'll check it out. [emoji106]
I’d like to know how he changed the top of the screen to Welcome Ty Pilot from the default Welcome Pilot?
If people would watch the video all the way through they would have seen you mentioned the the trim tab.?I did it on the video, not on the controller. ?
