How to turn of gimball mode
Poland
Hi guys,
I need to put termovision on to my ceiling, I had a problem with becouse when I'm incline my Typhoon it levels horizontaly camera.
Id like to turn off this function to have camera in steady position, does anyone knows if it is possible?
It is possible, but not on the H itself... you will need to obtain an Action Grip, designed to work with the CGO3+ camera. The grip has 2 modes, one will self-level... the second one does not.
Reactions: John Hennessy
Hi guys,
Put the tilt mode switch in position 3 (down = rate mode).
Then you can tilt up.
Reactions: JasiekKuna
Thanks!
I know about this function. The problem is this room is 3 meters high and is quite tight.
Time to be creative.
Maybe boot up, hit record, and don't arm.
Hand hold the plane and manually aim the camera against the gimbal's gyro push back.
Keep the recording short to avoid over stressing the gimbal.
Then stop record & power down.
Jimmyray
