Image capture fail
Fin
I have now had on two occasions a problem where the H520 doesn’t take images.
I program a mission with all the correct settings and start, the H520 flies to first waypoint and then starts the mission, but NO images are recorded. The little cameras don’t appear.
Nothing on SD.
I RTL and remove mission, format SD then re upload and start mission - It then captures images..
This is totally unacceptable. I have enough batteries for my missions charges and this loses one full charge.
Come on Yuneec sort out these bugs as this is not fit for purpose.
The system should take a test image before starting the mission to ensure that everything is ok.
I think it’s a glitch in the software, but has anyone else had this?
It is only on missions planned on PC and saved to the st16.
Similar issue. Mission planned on controller. Takeoff, does take planned photo at first waypoint. Programmed to start video at next waypoint and stop the video capture at last waypoint, then land. Consistently takes the photo, consistently no video. Comments appreciated. Thanks.
missudaipur53
