Indoor
No if the hanger is in a No fly zone airport. It won't even start. If you have your FAA 107 license and software code to remove No Fly Zone from Youneec, then yes - but you will only get it to fly 30 feet - no higher.
You can fly higher then 30' with the waiver. I have one and flew at an international airport with permission but flew no higher that 75' as was told by ATC.
Also if you fly in hanger turn off gps or it will go haywire.
Reactions: dartstar1
Thanks haven’t had the issue of starting up. I was really concerned if the typhoon performing in a metal building even with gps off with the signal bouncing ..played it safe and flew the breeze with controller
airconditionerservice
