See attachedWhere do you find the H520 integration kit?
See attached
See attached
The Parrot Sequoia+ has the sun sensor that will balance the calibration to match from day to day or each flight so you have true numbers. That is the + partI totally agree, before, when multispectral cameras were so expensive, it was still allowed, but today I don't know if there will be any agronomist who accepts it. In fact, even if you have a multispectral camera, if you don't give absolute values it will also make you look bad. To do this must use a calibration target, the same to all the successive sampling.
Here is the link that has the H520 with the Parrot Sequoia+ set up. This is the Nir camera and also has a regular camera inside as the 5th lense. Threw the research of this I have contacted Sentera for maybe using their Field Agent software with the E90 for Vari reports, being $29 a month for a full AG program is better and does more than anything else I have seen. Unfortunately, Sentera support team says they do not support the E90 in any way. So to use Sentera you need to have the Parrot Sequoiat or(+) or the edge red camera. Note also the power source for the camera is a little funky if you ask me.Dedicated mounting PARROT SEQUOIA+ or RedEdge camera for Yuneec H520 Drone
This tandem can perform vegetation mapping operations with ease of bigger and more expensive platforms, in the same time outperforming its class rivals.aeromind.pl
From what Parrot put on the information package the solar sensor is not included in the older model and you have to calibrate it with the target package. The plus is the newer version that will calibrate to a truer value due to having the sensor. I am very frustrated in just trying to find the best program for doing the wide range of work that the H520 can do in all the fields to hear about how the program works with a DJI product with limited information for Yuneec. What does Yuneec have to say about this? Do they recommend a particular program to use with their product? With the E10T coming out I would think they have to have made this camera with some kind of 3 party program for the processing of the images.Allow me to correct you regarding sequoia +. The sequoia + is exactly the same as the normal one but thousands of tests have been done in the factory to get values that are very close to the absolute values. The solar sensor does the same. What is the difference? That thanks to these values certain programs are able to support them and "not" need a calibration target. But beware, the last time i look at it only was supported by Pix4D, now I do not know how the matter will be. Therefore with a calibration target you can use the data with any program.
It's an advantage but at the same time it's a little tricky if you use a program that doesn't support it. That you use a program that does not use it? in 2 minutes you have taken pictures to target and in other two you have introduced the data in the program.
It took me a long time to find out how it really worked and I was a little angry because I had bought the normal version not long before the Plus version came out
In the end it was a matter of 150€ to buy a calibration target (from the Parrot brand itself because the rest I found cost at least 500€) and dedicate 5 minutes more work ?
If you would please give a list of or dozens of great mapping/Ag/Terrain specific Apps I really could use this information. ThanksIf you're looking for multispectral and not simply converting a single lens from CGO3 with a IR / NIR, your best option is one of several Multispectal cameras that includes an RGB (5th lens) as well. With analysis software & reporting, you'll need to provide actual images overlaid or on same report to provide the data needed.
If the products that support DJI platform don't settle with you, look at other specialized platforms. One being a moderate priced, Parrot Bluegrass full package including Pix4Fields software.
Use cases | Parrot
Parrot drones as seen by professionals: discover all the use cases and how our drones are being used to assist professionals.www.parrot.com
This totoal package integration is helpful with for learning, and obtaining support as you continue to define your ideal setup.
Plus you can easily adopt additional NDVI SW, or move the Parrot Sequoia multispectral camera to alternate platform. Actually you can mount the Parrot Sequoia on the belly of the H520 and mount the light sensor on top and fly the Ag Field with any Map software desired and continue using the CGO3 or E90 as your standard Nav Camera connected to ST16.
Revisiting DJI, the above scenario is basically what is performed on DJI too. You can use DD, UgCS, or dozens of great mapping/Ag/Terrain specific Apps with a multispectral mounted to the belly performing a separate collection.
DJI does not provide their own Multispectral camera... yet, nor focused Ag Terrain app.
If you're wanting to avoid purchasing additional platform, then look into the Parrot Sequoia Multispectral camera... it's offered in several other "Brand" labels or similar models by Ag focused Products. Check out Sentera or MicaSense RedEdge too.
Drone Systems & Sensors - Sentera
sentera.comRedEdge-MX — MicaSense
RedEdge-MX The technology you’ve come to depend on, now more durable and more accuratewww.micasense.com
I personally like the Parrot Bluegrass complete package... the hardware and Pix4Field is useable on other platforms but for starters it puts it all on 1 support team.
That all said, I too looked at modifying several CGO3 cameras, gave that up quickly as I discovered more withn the Ag desired requirements. And... you can mount a Multispectral & light sensor on any platform including the H520 easily.
Short side tangent. TH+ is only going to stay for the video and photography level. That is why there is a price difference between the two. Yuneec I think will not shot themselves in the foot over the profit differance and the work load capibilities.Sequoia:
I'm not confident on Plus vs Standard nomenclature; when I looked at them about a year ago they had 2 models and one included the Light Sensor to improve calibrations and grid readings. Assumed that was the "plus", maybe it was just "unit & light sensor". Looks like it worked out in the end.
Short side tangent... @SmokinAmerican
I'm with you on the E10T thought path. I use both DJI & Yuneec and for the 3rd party products: map, autonomous programming, 3D, Ag specific, etc it's pretty difficult to use platforms simply NOT supported and that's normally been Yuneec. Regardless of Brand opinion or the banter of Brands; in vertical markets or specific requirements, if one provides the industry accepted tools and the other lacks... a workable path is the path taken or simply take a pass on opportunity. I'm not that brand focused to ignore an opportunity... not practical if wanting to get into various opportunities. I've been holding off on either/both a Zenmuse XT 640 Radiometric and XT2 640 watching where the E10T 640 develops.
Although, I am encouraged... the last 6-8 months, the H520 package has improved and in the last year, 3rd party market started with advertisment chatter and now seeing 3rd Parties adding support for the H520. It's nice to see the H520 platform is finally being utilized and included in 3rd party retail SW development. It's not only a matter of being used in any 3rd party software & hardware, it's needing to be included in the "widely accepted" software & hardware recognized by clients or specified within business requirements for the projects. If the products support multi-platform: Inspire 2, Matrice 210, Matrice 600Pro and the H520; the H520 is more justified to purchase comparable to all platforms that can be utilized. Lower cost in Platform, lower cost Battery Pak, and lower cost of optional hardware: cameras, etc.
On the subject of the E10T, this is one Thermo Camera to watch. It's a FLIR sensor and it's basically a DUO (FlIR & RGB). The E10T with 640 Thermo, is now in the same ballpark as the Zenmuse XT2 at practically 1/2 the Retail cost ($7k vs 12-14K). If the E10T 640 can be used with SAR & Fire specialized, Roofing specific, Solar Panel specific focused products along side the M210, M600P then it's a Great solution at 1/2 the expense for the camera and a huge reduction in platform cost. It's not happening if it's solely Yuneec; it needs buy-in, it needs the acceptance of the 3rd Party too... and it's made huge strides in getting acknowledged during the last year. I'm a little confused why it's only the H520, I haven't seen any acceptance of the H Plus yet and that would be an even lower cost platform in comparison to both the H520 and DJI commercial platforms.
actually, I think their "supported" list of platforms is what they've mounted & tested. If you can mount it and configure a method to trigger it to provide consistent overlap throughout the grid, the GPS & Data within the Photos will be enough to process the IR or mesh points, depending what you're attempting. If you own their camera that includes a User Login to their service, I don't think they'd know or care what you mounted on. Some products the software integrates with platform control software, but for the independent collection if you can reliably trigger it on a autonomous grid... it'd work. Just my 2 cents.I am curious, If I send the pictures to a company that says they do not support the drone or the camera do you think they could still process the photos?
FieldAgent Platform | Agronomic Software | Sentera
For the cost of $29 a month and for what they offer I would be willing to pay if only the stitching and the field analysis would be worth it. If the pictures where jpg and renamed how could they tell where and what took the photos? Any thoughts??
Check out the few primary brands listed above, or Google them, the search results would point to various sites or competition to explore. Some take a bit of reading to see if it fits your scope, but the main Ag brands are a great start.If you would please give a list of or dozens of great mapping/Ag/Terrain specific Apps I really could use this information. Thanks
HI,Sequoia:
hi,Hi guys,
I use three E50s for multispectral work.
I need the relative response curve of the CMOS CCD sensor of the E50 to be able to calibrate my shots.
Can somebody provide me either the curve or the manufacturer's reference of the CMOS CCD sensor?
