Joy Stick / potentiometer
I'm looking to purchase a new
St16 joystick assembly. Yuneec skins does not seem to have a new one.
Mine needs spraying or cleaning way too often.
Is it really time for a new one ?
I wonder where I can get a brand new one.
Keith Kuhn
PS - is there a way
to save mine ?
Keith Kuhn
PS - is there a way
to save mine ?
Have you checked vertigo drones, carolina, or terrestrial imaging?
By the way, what frequency is “way too often”?
Jeff
Keith Kuhn
PS - is there a way
to save mine ?
What is the name of the product you are using to clean them with? If the product leaves behind any kind of lubricant, that is what is causing the problem as it will collect dust.
Reactions: Mike Irish
Jeff
I believe I checked vertigo drones.
They are out of stock.
I will check the others just to make sure.
Thanks Keith
One other thing to check.
Inspect to see that the pot is not moving in its pocket.
If it is not stationary, add a dab of hot glue so its center position repeats.
Then do a stick calibration.
Believe it or not I did that one time. Hot glued it.
I have two controllers but I'm not sure which one I hot glued.
Thanks for the tip though.
Keith Kuhn
Unpicked
