§ 15.203 Antenna requirement.
An intentional radiator shall be designed to ensure that no antenna other than that furnished by the responsible party shall be used with the device.
15.204 (c) An intentional radiator may be operated only with the antenna with which it is authorized. If an antenna is marketed with the intentional radiator, it shall be of a type which is authorized with the intentional radiator. An intentional radiator may be authorized with multiple antenna types.
If you are flying H+ Plus, currently the range is more than 1.5KM, is still not enough?FPVLR Yuneec Typhoon H Pro 3-Antenna Long Range Antenna Kit
Does anyone have an opinion on this? And is it worth $170?
The telemetry and control signal are very robust and need no antenna modifications. The video signal however definitely improves with a better antenna. Tree leaves or flying low will cause the video to break up at much shorter distances.If you are flying H+ Plus, currently the range is more than 1.5KM, is still not enough?
Which drone did you use? I can have a try to find if some tips can help on this case.I agree. I am very disappointed with the range on the video signal. i was shooting some land real estate video yesterday and the video link was distorting and dropping out at short ranges low to tree tops. Combine that with the lack of camera options such as thermal for the plus and I am second guessing my choice to go with Yuneec over DJI.
currently the typhoon H plus with c23 camera. The camera is impressive but versatility seems very lacking for a drone in this price range.Which drone did you use? I can have a try to find if some tips can help on this case.
You might feel that way, until you get locked out by DJI's overly aggressive geofencing that prevents you from flying. And you may, or may not, get unlocked. So every system has its pluses and minuses. Me, I like 6 props and not having to ask China for permission to fly the machine I have already paid good money for.
