k2 and k3 not working right since last update
Salisbury nc 28146
Since last update I have noticed if I goto hardware monitor and move k2 and k3 up and down . the graphic only show it working on the top half .
I have also noticed that I can no longer look straight down with the camera .
Anyone else have this issue ?
if anyone else runs into this this post cured my problem .
ST16 hided settings - better don't touch
i have found the bug Number 736 of YUNEEC :)
before you end the process of calibrate you must bring the sliders to the center-point of it...and then press finish...
but there is a little trick to find the center:
- i have tried to set by calculate the center with the results you get - don't work
- i have tried to use the optical way by look at the slider - don't work
if you have put your inputs of min max of all...then...before you end the controller give you a beep for the middle...let the slider k2 k3 at this place and then push finish ..... THATS IT
goldentrianglepackages
