Landing Gear
I purchased Yuneec H and have flown it several times no crash... Recently I noticed landing gear spreads too wide apart and so the camera is hitting the ground when landing or just placing the Drone on the table the.landing gear slides and the camera rests on the surface...how do I correct this problem?? Please help
Sometimes shipment causes landing gear to "stick" or not operate completely.
Aside from contacting Yuneec, try this first.
With the props off, ST16 landing gear switch in the "down" position, turn of the ST16, then turn on the H.
Holding the H with your hand, turn it completely upside down.
Now flip the ST16 landing gear switch to the "up" position. The gear should cycle up.
(The H must be upside down because the gear will not raise at low altitude, you are fooling it's sensor)
Flip if back over and the switch to "down" again.
Do this several times.
Good luck.
Sounds like the retaining washer inside the servos has popped free. You will need to open up the motors yourself if you don’t want to create a warranty ticket and wait.
costimarcos
