Logs from St16s are inaccurate H Plus
Peggy
Premium Pilot
Word of warning.
I have downloaded the flight logs from the st16s and from the aircraft.
Too say the st16s logs are far from the truth would be an understatement, however the logs from the aircraft are bang on.
If you need to comply with logging your flights please use the aircraft ones.
These can be downloaded via QGroundControl to a pc or Mac but use the latest version. Simply plug in your Plus via usb lead and start up QGroundControl. Look for what looks like a notepad icon at the top left, click it and then on the right click refresh, select flight logs to download and boomshakalaka it’s done.
Reactions: Ty Pilot and Barton
Yes, you are right, inside the ST16S telemetry data there are a lot of unusable datasets, destroying the whole picture. I did some effort to filter out those useless datasets.
Remote and RemoteGPS are OK so far. RemoteGPS has now the number of sats of the ST16-GPS. That's good. Telemetry has got vSpeed and hSpeed, that's also good. But Pitch, roll, yaw and gpsAccH are not supported any more. Current contains nor the Ampere as expected but the remaining LiPo capacity in %.
Vehicle Type is still 5 and points to Typhoon H but it is meant a H Plus - sad.
Sensor files are completly different to Typhoon H. Still we don't know what is in. No documentation.
With q500log2kml you can filter out most of the useless datasets (set "TH+ clean" to checked at Settings/Data analysis).
Windows64bit: http://h-elsner.mooo.com/downloads/q500log2kml_en.zip
LINUX 64bit: http://h-elsner.mooo.com/downloads/q500log2kml_en.tar.gz
User manual: http://h-elsner.mooo.com/mydat/Q500log2kml_en.pdf
Reactions: Peggy
I upload my txt reports to DroneLogbook, it decifers the information needed to complete pilot logs
oliver555
