Hey all, long time no post! ...I've been great, thanks for asking!
After breaking out my H Plus after 9 months of storage, there is good news and bad. The good news is the batteries are in great shape -no swelling and all cells were still well balanced, I stored them with a storage charge and they charged right up and work great.
The bad news is I have a gremlin now that makes it hard to use the setup. I have two ST16s controllers for Team Mode which I use often. My primary controller (for flight control) has an intermittent problem with the GPS. Most of the time after power up, the Sat icon shows "N/A" and is greyed out. I can power cycle it and sometimes it will start to work normally and indicate the number of sats, other times not. Most of the time (8 out of 10) it shows N/A, and I can't fly.
My secondary ST16s seems to work fine, no GPS issues, and I can swap them, but it is set up to operate the gimbal with a custom rate curve for just that purpose, it is not set up to control the aircraft like my primary ST16s, which has different custom rate curves for flight control.
Does anyone have any idea what is going on with the GPS in my ST16s and what I need to do to fix this issue? Thanks!
