Loose tiny cables on GCO3+ camera
Replacing the lens in a GCO3+ camera, accidentally disconnected the 4 tiny cables that goes from the right arm of the camera to the board behind the lens, can not figure how to reconnect it again, the only thing noticed is the 2 of them are shorter. Will appreciate any help. 2 photos attached
You will have to disassemble far enough to access the gimbal control board and use needle style probes on a DMM to continuity check the wires. Use the photo information from @h-elsner to resolder the wires to the correct pads.
You can find instructions for disassembly and reassembly in the Way to Fix Drones Project Way To Fix Drones project
You will need a multimeter to tell which wire is associated with each pin on the gimbal board.
This drawing will show the location ("D") of the IMU connector on the Gimbal board:
CGo3+ Gimbal Board Connections
This drawing will show which connector pin goes to each pad on the IMU:
CGo3+ IMU Pinout
As mentioned by @DoomMeister above, Steps 1 through 11 of this document will give access to the IMU connector on the gimbal board:
CGo3+ Gimbal Board Removal
Reactions: DoomMeister
Sacha
