Has anyone had this problem. Yesterday after a flawless day of flying the H+ I tried to remove my SD card. I had difficulty removing it and it required using a tweezers to get it out. Regardless of micro SD card I try to insert it will not go in. I'm planning on doing 3 weeks of work in the 4 Corners primarily in New Mexico in mid-November. I need a rather speedy solution. Issue is the spring mechanism I believe. Has anyone else had this issue? Cards have always been properly inserted and all data written to the card yesterday was flawless upon download.
