MK58 specs?
Never tried with ST24 and MK58. Tested only with ST10+, where everything was fine. Didn't test without a camera attached. Probably there will be a green screen. The camera was a simple FPV camera.
No way to reproduce the tests now. I'm focused on different problems.
ST24 is for ZigBee RC connection and has nothing to do with the camera in this case. MK58 is connected so far. It there is no live video then it could be video connection as stated above.
DA58 or ADA58 may be for cameras that are no more supported. ST24 contains some functions that are planned in the past but never developed later.
There is a camera connected, just not a gopro. This MK58 and camera setup transmits the live video when I bind it to an ST10 . I might try again with another MK58 module.
I'm wondering if the gimbal for the GoPro (which I dont' have hooked up) sends something to the FC, which then tells the ST24 when it is initialized via the SR24? I didn't think there was a lot to the gopro gimbal setup, but maybe I need to look at it more.
Sends exactly nothing. The gimbal is only directed in tilt plane via PWM and there is no reverse data or something like this.
I'm not sure when ST24 was produced MK58 for FPV camera (GoPro) was on the market too.
Where is the reason to not use ST10 or 10+?
I bought the ST24 to experiment with, so I'm experimenting. I like the size and layout of the ST24 (and ST16) better than the ST10 or 10+. The extra channels and switches on the ST24 may be useful for some projects.
Sacha
