Mounting GPS?
Hey can someone tell me which way the GPS is mounted, Wire to the front are wire to the back?
Thanks
There is no arrow on the PCB?
As I can see in the pictures, on the PCB is the GPS only, so direction doesn't matter.
Reactions: Gunit
Probably yes.
What is on this IC marked?
You can see a module from H480, there is a compass... Just a second I did a topic with questions about these modules.
Reactions: Gunit
All of the other Hex series from Yuneec have the wires at the rear of the aircraft. I would suspect the 920 series is the same.
sao789ph
