Thanx I got the hex drivers, just ordered the phillips #0. #00, and #000This is the driver set that I use. It is superior quality.
RC Screw Driver Kit with 4 Hex Screwdrivers
or
https://smile.amazon.com/NEEWER®-Titanium-Nitride-Driver-Wrench/dp/B00CP2GGBI/ref=sr_1_7?keywords=4+hex+screwdriver&qid=1573327480&sr=8-7
As far as small needle nose pliers, I have hemostats which should sufficeThanx I got the hex drivers, just ordered the phillips #0. #00, and #000
Maybe a 3lb. sledge, when the others aren't workin ?As far as small needle nose pliers, I have hemostats which should suffice
What about the Lens removal tool for under the motor, and arm, can be very difficult to remove without.There will never be an end to "I need a ..." for those of us that like to tinker, but here is a good start:
Set of magnetic hex drivers that include 1.5mm, 2.0mm and 2.5mm.
Set of magnetic screwdrivers. (Lots of “electronics” sets out there)
Set of non-magnetic, anti-static tweezers.
Small needle nosed plyers.
Soldering iron and accessories.
Are you going to kidnap a Kav technician!Don’t forget duct tape and baling wire.....
I can vouch for duct tape, the aluminum type not the cloth type.Don’t forget duct tape and baling wire.....
