- Joined
- Mar 30, 2018
- Messages
- 5
- Reaction score
- 0
- Age
- 68
just got a new breeze and it will not fly higher than 12 feet ,.. i connect fine to the drone, but still only 12 feet high. i am reloading the program to my phone to see if that helps...
Thank youGo to this government website and zoom in to the exact area you are trying to fly. You may be in a restricted altitude zone as determined by the FAA.
ArcGIS Web Application
Did that help? I suspect you are in an area very near to an airport or major sports stadium.
Thank you, that will helpUnsure if no satellites will limit your height but I think so. Check to MAKE SURE you have 12+ Satellites OUTSIDE - mine takes 2 on/off sequences to find satellites - yours may too. BE SURE to have satellites connected for GPS and safe outdoor flight. Always check this - then you will be safe(r) when flying.
When flying indoors you DO NOT want satellites (GPS) so you disable the GPS on the phone screen. If you are unsure of how to do this - read the brief manual or check YouTube videos.
Small housing area, with business. I think you might be right I was flying indoor mood and it has a max height. Going outside mood today. If this is a factor. I like breeze even more... Was trying to do a fly in to a sign, but sign is 25 feet up... Will let you know, thank you, o for got I did check that flight height and that area has a 400 ft height. But by airport a 0 height...Where are you trying to fly?
