No video after upgrade
Hi
Upgraded to 1.1.03.20190312 today and everything looked fine. but no contact with the camera.
It binds to the camera but that's all.
Gimbal works
Hi, what is your build ? 822/829 ?
if that's it, I had the same problem, go down to 784
Try going into the camera setting and switch it to AUTO, or adjust the manual settings. When I upgraded once before, it was in manual mode and adjusted my camera settings to the point that the screen was black.
The screen is not black. The wallpaper images/slideshow is running. Can't change camera settings since i have no contact with camera. All camera info ISO/Shutter/WB etc has N/A values
Reactions: TurboDad81
I see there are C and E versions of the c23 files in the yuneec.ota folder. Can this mess up things?
And on the sd card in the camera there are autopilot.yuneec.updated and gimbal.yuneec.updated but not a c23 file. Is that correct?
Unbind you camera.
Copy the C23 file according to your country C23_C for China/US. C23_E for U.K.
* Change the extension ‘.yuneec’ to ‘.zip’ unpack.
* Copy the camera.bin to a formatted micro sd card.
* Load as card to C23.
* Cycle. C23 camera will blink red, when processing and green when finished.
*Check sd card.
The bin file should automatically been deleted.
*Cycle ST16s and C23
*Rebind C23
DHYradio
