One landing will not go down
This is my 2nd flight of this used typhoon h and this happen, one landing gear will not go downScreenshot_20161106-082727.png
Sent from my SM-N920V using Tapatalk
You can also remove the camera, power up the st-16 and the aircraft, (No Props) flip the H up side down and operate the landing gear up and down.
Like Billy suggested there are 2 hex screws (2mm I think) holding the gear in place. Remove the screws pull straight down, clean the contacts and put it back together.
Here is a good video of someone taking the H apart to repair his camera, but you can see how the landing gear come off. Watch from the 9:00 minute mark on is where he removes the landing gear.
Let us know how you make out.
Removed gear and cleaned contacts and all seem good, I engaged them several times and they worked
Reactions: BillyTexas
It's not a problem, it's a FEATURE! /s
For future reference you can test landing gear on the ground by flipping the H upside down and flipping the landing gear switch.
csandoval
