Pan Control drifts in center position
Been setting up my Typhoon H for first flight and went through all the required configurations and tests. I noticed if I switch the PAN switch to center and do some rotations and the switch back to F the camera still tends to rotate very slowly for a short time and does not go to front position. Is this a bug. Running all the latest SW and FW.
Thanks
It's the factory setting.
We don't have access to the gimbal servo's PID tuning values.
Just to be sure, Redo the ST16's calibrations to confirm that the pots are centering.
I've had my H not quite two years. I don't use that feature very often and when I do I have that same issue very intermittently. Rebooting the bird resets it everytime when it does. Since I use it so infrequently I just plan my flights around it.
Thanks for your input seems to work now
mindfiresolutions
