Post Crash Camera Problems
Hello all!
So I suffered my first crash yesterday and after repairing the blades my CGO3+ camera won't show up on my control board. I can move it (tilt, pan and what not) from the control board but the video still won't show up. I have tried rebinding it several times and it still won't work. There is no CGO3+ option as a camera selection to bind with just C-GO3, C-GO3-Pro, C-GOET and C-GO4. I have tried all of them with no luck. Any thoughts?
Sorry about your crash - what happened ?
On mine the CGO3+ shows up in the list as CGO3P, and that works here, so presumably is the one you need too...
But if you have control of the gimbal that suggests you are already bound to it, but that the camera / transmitter in that is simply not working after the crash - how badly did it get bashed ?
The wind took it into a light pole and it hit the ground and bounced around 2 or 3 times. The pin hole above the camera is green and it just keeps saying that it can't connect to the camera. Thoughts?
The video feed is the 5.8 GHz signal on the mushroom antenna and the pan and tilt controls are on the 2.4 GHz antenna. So if you don't get video feed there is something wrong with the RF signal from the camera. Turn on the controller and the H. Go to pad mode, settings and wifi. See if the camera is listed as an available wifi connection. If it's in the list then the camera wifi is working. Post your findings here.
I did what you said and it shows up in the WIFI selections. When I try to connect it says that there is a Authentication Problem. The icon to the far right where it shows you the strength of the WIFI signal shows a lock sign on it but it does not ask for a password or anything like that.
It does say that there are 4 "bars" on it though, like it is connected but the camera still does not send a feed and it says that it has an Authentication Problem.
Tonymus
