Bob, yeah the rules pertaining to our aircraft are very fluid at the moment, one minute you had to register the next you didn't. Some do register now, but if your going to get a 107 you will have a different registration under that rule so its up to you. As for my strap, I attached clips to the side of my sunshade and attach the straps there. Others have noted that the little pins that hold the sunshade are all that is holding the transmitter, but I usually never take both hands off the controller and I check them regularly.
Very nice photos indeed, but not what I would call "sunset" or even remotely "low light"...I would call it really late afternoon? I joke with you a bit...uhhhmmmm.... Aerobotik Aerial Imaging
What ISO and shutter speed did you use, any filters?Very nice photos indeed, but not what I would call "sunset" or even remotely "low light"...I would call it really late afternoon? I joke with you a bit...
For my purposes I mean the point when the sun actually starts to set behind the horizon, IE low orange light, you might say dusk even. I have tried every setting, manual modes no matter what I get massive pixelation, if you have suggestions to remedy I would be much obliged. I have photos taken literally 10 minutes before with same settings and they look fine, no pixelation, just in low light is it an issue. My Note 4 takes better low light photos which is just sad.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
