Real Sense does not work? Not it ever has “Not Available”
In the photo it shows the OBS in yellow and the wearing message in the center “not available”. Do I have to be flying or outside. Or is there something else I need to do to get this to work?
I get a solid purple with white flashing = Angle
I get a solid green with white flashing = Smart
I get a solid red with white flashing = Home
What does a flashing white light mean?
The flashing white indicates the GPS is working.
Try the RealSense when you are flying and see if it works.
Believe you have to be airborne, with the landing gear up and at least 10 ft in the air for OBS to work. In addition you must turn RS on.
To Enable the RealSense Module if installed tap “System Settings”, tap “Other Settings”, check the box next to “RealSense Installed”.
To get more specific, the flashing white indicates enough satellites have been acquired by the ST16 to enable the smart modes such as Follow Me.
The threshold is 10. Not 9. Not 11. 8 is right out.
:D
Jeff
Frida Gold
