realsense fan
Can you get just the fan for the realsense module or do you have to buy the whole module. I had a fan blade break off some how. Can I run it with one blade missing
I’ll venture if the case of the RS can be safely separated snd reassembled it will use the same fan found in the ST-16, which can be purchased and installed.
you got a part number and a place to get it??
I placed an order for the realsence fan, cover for the realsence , cgo3+ top mount set and cgo3+ housing.
Shipping was $9.95
I noticed the fan blade missing after a year of operation.
Never any abuse or hard landings.
May be a defect in the mold or stress in assembly.
It was a chore to disassemble the realsence as the components are stacked. Be careful of the ribbon cable.
An extra pair of hands to hold the components definitely will speed up the process.
Good luck
Yes I used the realsence with the blade missing. Not intentionally.
I noticed it after a day (6 battery) of flying.
Now I look carefully at the fan after every flight.
revile
